Trim/Extend Pipe Tool question
I am wondering if the trim/extend pipe tool could be used to extend a pipe, For example if I have two pipes butt up against each other, can the "trim/extend pipe tool" be used to extend one of the pipes into the other pipe as if it were a swage end? So, my end product would be to have the one pipe extend into a swage end pipe instead of a fitting? or would I need to find another way to make that process happen?
salariua
Trim/Extend can only be used with open ends, end nodes.
Here's my post on this:
http://blog.ads-sol.com/2015/07/inventor-tp-trim-extend-pipe.html
To simulate swagged, butt welded (melted into another). You need to change your engagement distance to create an overlapping connection.
http://forums.autodesk.com/t5/inventor-general-discussion/t-amp-p-trimmable-fittings/m-p/5548863/hig...
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
