Translucent Materials are invisible infront of a sketch with an image
- Mute
- Permalink
- Report
Hello Autodesk Community!
I recently switched over from Inventor 2018 to 2021, and I am having trouble seeing translucent parts. In Inventor 2018, you could put a sketch with an image down, make a new sketch and extrude a profile with a clear material (e.g. clear green or clear blue), and see both the image behind and the extrusion.
However, in Inventor 2021 you can't see the part that you've just extruded if there's an image behind it. Removing the image solves this, but then I can't trace it. I could also set the material to something solid, but then I can't see the thing that I'm trying to trace.
Does anyone have any idea how I could trace an image whilst also looking at the parts I've already extruded, in Inventor 2021?
Kind regards
Leo
Inventor 2021, can't see translucent extrusion if it is over a sketch
Inventor 2018, you can see the image and the part simultaneously
Inventor 2021, extrusion is visible if image is removed
