Announcements
TOTAL INCHES OF ENTIRE SKETCH
jbarnes84SUH
jbarnes84SUH
Hello all , is there a way to compute total inches of length of an entire sketch on Inventor? i usually have to switch to auto cad , i would like to do in Inventor if possible.
Replies (8)
Mario.VanWiechen
Hard to make it parametric but if you have a length dimension on every sketch entity you want to measure you can add all op them in parameters
ldutkaTUZ58
??????? Huh??
jbarnes84SUH
Its for computing inches of knife rule for quoting cutting dies. Like i said i have a way to do it on autocad , I was hoping there was a trick for figuring out in inventor, similar to how it measures the perimeter of a face.
ldutkaTUZ58
Oh, ok,, I think try "Inspect", then "Measure". If you want more extensive, then right click on the name for the "iProperties" , then the "Physical" tab. Then select what materials you're using. Good luck.
harvey3ELEA
There's a cumulative option when using the measure tool as well.  A little green "+" sign appears in the blue margin (it's not the fixed "+" at the bottom right of the measure window).  I'm not terribly good with it, but see if you can use it for your purposes.
ccec_ireland
I agree with what @Mario.VanWiechen is suggesting. Create a new total length parameter in your parameter table and define it as the sum of all of your other dimensions that represent an edge length. Something like Total_Length = d0+d1+d2+d3 etc. You may have to add dimensions to your sketch that you normally wouldn't bother with, like arc lengths, but once done it will update dynamically. I don't know if that's faster than exporting to dwg, but it should work.
2025: AutoCAD, Inventor, Inventor Nesting, Vault Pro
blandb
In the sketch, inspect tab > Region Properties > Choose the profile > choose dual units it needed does the same as if you manually added perimeter:
Autodesk Certified Professional
jbarnes84SUH
I like this solution thanks!
