[Tool] Convert Polyline to Spline (2D)
weiser
Message 1 of 22
weiser
Hi there,
after asking quite a few questions in the forum I think it is time to give something back 🙂
So here is a little tool for converting "connected" polylines, given wihtin a 2D-sketch to a spline fitting to the points.
It's a user form written in VBA.
Though I'm going to it to redesign CAD-models from STL-Scans by creating cross-sections, I arranged a few options within the form for modifying the given points.
Right now the GUI is in german ...
Hope someone find it useful.
Regards
Replies (21)
Message 2 of 22
johnsonshiue
Hi! This is a very interesting tool! I know it will be very useful for imported dwg files. Have you thought about submitted it to Inventor App store?
Many thanks!
Software Test Engineer
Message 3 of 22
weiser
Hi @johnsonshiue ,
thanks for your answer. As I mentioned I'm just trying to get "smoother" cross-sections from STL-models ... So when coding I did not think about other usage at all....
I did not get into contact with the app-store nor know how to build an app.
Therefore I posted the zip-file so that everyone is able to import the code into their VBA-project.
Is there any tutorial / manual how to "convert" a VBA-user form into an Inventor-App?
Regards
Message 4 of 22
johnsonshiue
Hi! I am sorry I am not a developer. Nor am I an App creator. You could send an email to appsubmissions@autodesk.com and see how it goes.
Many thanks!
Message 5 of 22
GeorgK
I tried to convert it to VB.Net. There is an error in the.
Private Sub PreviewPoints()
        ' Generierung der Liste der aktuellen Punkte  ' Erstellen der Punkte und Hinzufügen zur Punkteliste
        Dim oSelectSet As SelectSet
        oSelectSet = m_inventorApplication.ActiveDocument.SelectSet
        oSelectSet.Clear()
        Dim oTransGeom As TransientGeometry
        Dim nPointPreview As Object
        'Dim nPoint As Object = Nothing
        oTransGeom = m_inventorApplication.TransientGeometry
        Dim oPreviewPoints As ObjectCollection
        oPreviewPoints = m_inventorApplication.TransientObjects.CreateObjectCollection
        Dim oPoints(nPoint) As Point2d
        For i = 1 To nPoint
            ' Generieren des aktuellen Punkts
            oPoints(i) = oTransGeom.CreatePoint2d(oPointCoordX(i), oPointCoordY(i)) '==>>> Error
            ' Aufnahme des Punkts in die Liste
            oPreviewPoints.Add(oPoints(i))
        Next i
        'oSelect.Select oPreviewPoints
        ' Hinzufügen der Punkte zur aktuellen Ebene
        Dim oSketch As PlanarSketch
        oSketch = m_inventorApplication.ActiveEditObject
        For i = 1 To nPoint
            ' Generieren des aktuellen Punkts als Mittelpunkt (mit Markierung)
            oSketch.SketchPoints.Add(oPoints(i), True)
        Next i
        ' Warten auf die Bestätigung
        MsgBox("Vorschau beenden")
        ' Löschen der aktuellen Punkte
        nPointPreview = oSketch.SketchPoints.Count
        For i = nPointPreview To nPointPreview - nPoint + 1 Step -1
            '  MsgBox "Typ: " & TypeName(obj)
            ' Selektieren des aktuellen Punkts
            oSelectSet.Select(oSketch.SketchPoints(i))
        Next
        oSelectSet.Delete()
    End Sub
Thank you
Georg
Message 6 of 22
GeorgK
Message 7 of 22
weiser
Maybe someone is interested in another tool too ....
It is for building lines on mesh-surfaces:
https://forums.autodesk.com/t5/inventor-forum/tool-curves-on-mesh/td-p/8830791
Message 8 of 22
S_May
Hi @weiser
echt sehr coole Tips!!!!
Message 9 of 22
weiser
Tanks for the positive feedback!
Though this is just an information and not an unanswered question, I'll close it by accepting this as an answer 😉
Message 10 of 22
Sergio.D.Suárez
Hi, I'm going to ask you a trivial question for you, where do you place the zip to load the tool? I would like to try it. Some time ago I think I came across a similar thing but the description seems more interesting your tool. Best regards!
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 11 of 22
weiser
Hi @Sergio.D.Suárez
the question is not that trivial as you might think .... because I only did the export from the vba-editor ... never tried to import - 'cause the code is mine 😉
... but I think that's the way it should work:
Within the zip-file there are two files (*.frm, *-frx) I think that one should be the GUI (frm) and the other (frx) the code behind it .... So I think you have to import both files and hopefully that's it ...
To place an icon in Inventor's ribbon bar (group user defined commands) I've placed another Module within the VBA (see attachment / .bas within the zip-file) which is calling the userform.
Hope that helps you out.
Would be great to get feedback just to know if my theory is working 😉
Regards
Message 12 of 22
Sergio.D.Suárez
Import the form from the VBA editor, the one from the polyline is great, the others I have not tried yet! Congratulations, excellent work!
Mechanical Designer
Message 13 of 22
weiser
Hi, just red the article from below.
Seems to be that you extracted both files into the same directory and Inventor imported both (though you just selected one).
If you have any ideas for improvements, let me know 😉
About importing userform in VBAAbout importing userform in VBA
taken from https://www.excelbanter.com/excel-programming/430142-re-export-custom-form-frx-frm-files.html
Message 14 of 22
GeorgK
Hello@weiser ,
realy great tools.
Thank you.
Georg
Message 15 of 22
Hello Sergio I am in great need of this tool. Solidworks has a stock function equivalent called "Spline Fitting" but I need the same function in inventor and this is it. But, I am not familiar with visual basic or have the program. You seemed to have got it to work, would you please type a short step by step how? I see your reply of importing it from VBA but then i think "How am i going to import a file from another program from another program?" I'm just not familiar with that process of implementing the code or function into inventor. I've never done a custom tool before.
thank you for any thing you can help with.
-Ian
Message 16 of 22
luca_delbarba
Translated in English.
Everything seems OK.
Tested in Iventor 2022.
Message 17 of 22
luca_delbarba
Message 18 of 22
weiser
Hi @Sergio.D.Suárez
Thanks for translating and "supporting" the tool. It is always good to see that my effort is going to be usefull for anyone 👍🏼
Message 19 of 22
twagnerEA4R7
How do you import the .frx file into Inventor?
Message 20 of 22
twagnerEA4R7
How did you import the .frx file into Inventor?
