Hi all
I have a multi sheet drawing. I have the scale note setup in the title block to be assigned automatically via sheet properties.
All good. works well.
Sometimes however, I need to just change the scale details on one sheet only to read differently (in this case I need it to say 'varied'). Can this be done for one sheet without affecting the auto settings of the other sheets? Can I individually change the setting for one sheet only?
Solved by SBix26. Go to Solution.
Thanks Anoor
I understand the prompted entry, but I was trying to get away from that. Nearly always the scale is right, just sometimes it needs changing.
Copy your current title block to a new one called 'Scale Varies', or something like that. In the new title block, change the Scale property to static text that says 'Varies'.
Whenever needed, remove the default TB from that sheet and insert the Scale Varies TB instead.
Sam B
Inventor Pro 2019.1.2 | Windows 7 SP1
LinkedIn
