Guys,
I am having a problem getting my title block to print out correctly. I have attached pdf to help with the explanation. Page 2 shows as I see it on the screen. Page 1 shows the preview. You can clearly see the distortion of the bit map I added (Norwegian Electric Systems) And when I print it this Logo is not there at all!!
The preview shows the logo at its original size.
Any Ideas!?!
Michael Shelley
Solved by Daren.Lawrence. Go to Solution.
We'll start with what version, and did you make the title block from skratch or is it a ACAD block brought over?
msk
Hi Michael,
Check out if the logo is in the same directory as your drawing template. As for the distortion - the Page 2 looks OK to me. Unless I am missing something out.
Igor.
Michael
There is a hotfix for this on the Autodesk website.
Regards
Martin
The hotfix Michael is referring to can be found here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15192521&linkID=9242019
Please let us know the results. Thank you.
