Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Title Block File Location
JoelMckone
JoelMckone
Whenever I select 'edit definition' for custom title block I use, the error message appears:
I would 'add this file to a valid search path' if I knew where the file was located.  I am guessing it is the 'company BOM' custom title block but a search for the title block name does not locate the file.
This is not a big concern but it would be nice to be able to remove this error message - any suggestions on how to resolve this?
Gabriel_Watson
Did you include some sort of company logo image that was imported as a linked item? You may have to break the link if so:
JoelMckone
There is an bmp image for the company logo.  This is linked to the title block through a library folder called 'images and table' (Unfortunately the company has not upgraded to Vault).
Breaking the link does solve the error message but (of course) removes the logo from the title block.  Is there a better place to keep the logo or change link to 'workspace' or 'workgroup search paths'?
Gabriel_Watson
Consider deleting and then re-inserting the image without the "Link" checkbox marked, as seen above.
JoelMckone
Thanks - missed that details the first time around but  the error message is gone and the  logo is still in the title block.
