Title Block copy and paste changes my text style
shastu
Advisor Advisor
shastu
I have a template file and I want to use the title block ANSI A in another file.  The text within the ANSI A definition of the template is of the style "BOM".  Once I copy it into the file, it no longer uses the "BOM" Style, but instead uses the "DEFAULT-ANSI" Style which is set to use a bigger text.  I want it to stay exactly the way it is in the template.  See attached files.  Open the PART template.  Edit the definition of the Title Block "ANSI A".  Edit the text called "<STOCK NUMBER>.  You will see in the top left had corner that it says "BOM".  Hit the "cancel" button and then the "Finish Sketch" button and then "no" to save it.  Right mouse click on the "ANSI A" under the Title Blocks in the Browser and then left mouse click on Copy.  Open up the drawing test.idw and paste it.  Then go check the same text and instead of the "BOM" style, it now reads "DEFAULT-ANSI".
Cadmanto
Is the format you are copying from and to come from the same template?
I copy and pasted the title block and haven't had this issues when coming from the same project file using the same styles.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Best Regards,
Scott McFadden
(Colossians 3:23-25)
shastu
Did you use the same files that I posted?
shastu
Yes,  I am replacing the existing.
Cadmanto
I did not use what you posted.  I will try this later when I am at home.
I was just asking general questions to see if it can be resolved without having to use your posted files.
Inventor Pro 2020
Best Regards,
Scott McFadden
