Thread Modeler
Thread Modeler
Message 1 of 18
Thread Modeler
Hi everybody,
I installed Coolorange.com for real thread modeler in my inventor and was installed successfully. The problem is still not shown in my inventor ribbon or coolorange logo.
It's shown in my files was installed already. ( see attachment)
Anyone can help me for this problem?
Daniel
Accepted solutions (3)
Replies (17)
Message 2 of 18
Open your Add-In Manager and see if it is loaded?
Message 3 of 18
I check in my manager account, but this not show up.
Also I Check and try from inventor Tools, Customize, Ribbon, also not show up either.
Daniel
Message 4 of 18
Hi Doug,
I reinstall coolorange thread modeler and now show in desk manager, but still not shown in ribbon.
What else should  I do.
Daniel
Message 5 of 18
You may have to restart your computer?
Message 6 of 18
I restart the computer, still not show up.
Message 7 of 18
-niels-
Maybe the Cool-Orange's wiki page can help?
http://wiki.coolorange.com/display/threadModeler/Installation
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 8 of 18
Good Morning Neils,
Thanks for your respond for my Thread Modeler problem
I check in Add-In Manager and coolOrange-ThreadModeler shown already loaded, but still didn't show up in Tools-Ribbon.
Also I restart the pc, not show up (see attachment)
What should I do now?.
Daniel Purnama
Message 9 of 18
JDMather
Tip:  Windows Snipping Tool.
Message 10 of 18
Mark.Lancaster
@Anonymous
It sounds like your add-ons are not registering properly...
1.  Exit Inventor.
2.  Select the WIndows Start button and type in the search field CMD (but do not hit an enter)
3.  When command prompt appears in the list, right mouse click on it and select run as administrator
4.  Navigate to C:\Program Files\Autodesk\Inventor <version>\Bin
5.  Type Inventor.exe /install
6.  Wait a few minutes
7.  Restart Inventor.
Mark Lancaster
Message 11 of 18
-niels-
In your screenshot you can see that there is a "coolorange" tab.
The addin is not located on the "tools" tab.
Niels van der Veer
The Netherlands
Message 12 of 18
Hi Neils,
Thanks for your help, I really appreciated.
You are right that shown not in tool ribbon and now worked perfectly and beautiful.
Thanks again,
Daniel Purnama
Message 13 of 18
Hi, anyone have a copy of Thread Modeler for Inventor 2016?  CoolOrange do not support anymore that version.
Thank's!
Alain
Message 14 of 18
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous you can contact support@coolorange.com and see if they will email it to you directly.
They might not be supporting it but would be interested to see if it still runs on 2016 regardless.
Have you tried downloading it and running on 2016? Is there a prompt that tells you it doesn't work?
Please select the Accept as Solution button if a post solves your issue or answers your question.
Message 15 of 18
Hi Kelly, I did contact CoolOrange, there is no way to have that release!!!
Message 16 of 18
-niels-
Not sure if this works, i won't take any responsibility for this, but try the following:
1. Install the current Thread modeler addin
2. Go to "C:\ProgramData\Autodesk\ApplicationPlugins\coolOrange_coolOrangethreadModeler.bundle\Contents"
3. Open "coolOrange.ThreadModeler.Inventor.addin" with a text editor (notepad)
4. Change the line "<SupportedSoftwareVersionGreaterThan>??..</SupportedSoftwareVersionGreaterThan>" to your required version number.
(i believe 2016 is "20")
5. save it and see if the addin loads...
Niels van der Veer
The Netherlands
Message 17 of 18
Hi Niels, CoolOrange told me last week to put 19 at "SupportedSoftwareVersionGreaterThan", and it was not working, but I tried 16 this morning, and guest what?  It works!  ;o)
Thank's for the additional tip.
Alain
Message 18 of 18
Worked for me. Thanks.
