Thread data error content center error
andrew_canfield
andrew_canfield
I usually work around this, save as, edit & import to fix the issue.
The content center manager doesn't appear to recognize the ISO Metric profile in the thread.xls file (which has been edited) - which could be the cause of the problem!
andrewiv
That message is not telling you that there is a problem with the thread.xls file.  It is telling you that you cannot change a library part.  You need to create a special project that has the library path as the workspace to be able to edit the files in the library.
Andrew In’t Veld
Designer / CAD Administrator
andrew_canfield
Hello
CC creates a part with a 1.6 pitch thread - a small i is displayed next to the thread feature in the browser.
this thread is also  ACME & iso is requested in the CC manager.
I can swap out the library part but it's a faff.
Regards
Andrew
johnsonshiue
Hi Andrew C,
I believe Andrew IV is right. This is about the ability to modify files stored in a library folder, unrelated to thread table. Any file stored in a library folder (within the active Project) is considered readonly. Inventor will complain when you try editing it.
Many thanks!
Software Test Engineer
andrew_canfield
Apologies for the poorly worded question, I've skipped over the problem trying to guess the answer.
Going to the content centre manager copy & paste the M7x25 line, edit to M7 x 20 - place the part for the very first time and.. an incorrect thread is applied to the part (that's the problem).
1 - Warning appears
2 - i in browser next to thread
3 - two M7 fasteners together, M7 x 25 has the edited thread applied
4 - the M7 x 20 will have an ACME M1.6 thread applied (which isn't on the CC editor row - eariler post).M7x20.jpg
Regards
Andrew
johnsonshiue
Hi Andrew C,
No need to apologize! I did not understand the issue clearly. I will work with the project team to see if this is a known issue.
Many thanks!
Roman_Vesely
Hi andrew.canfield,
 thank you for your feedback. I tried the same on the latest version of Inventor 2021.1 and if I change correctly also other values - especially both columns with caption "Nominal Diameter" but different column name "NND" & "THREADDIA"
I can see that inserted part has correctly applied thread
Regards
 Roman
Roman Vesely
Inventor - Principal QA Engineer
