Announcements
Thin rotor lamination FEA
I am designing a motor rotor made up of thin laminations. The rotor is over 1m in diamter and the laminations are 0.5mm thick so Inventor catagorizes it as a thin body. The rotor is made up of a stack of laminations glued together with an epoxy resin. At this stage i am ignoring the epoxy resin.
For now i am attempting to model a small number of laminations (50 of) using the find thin bodies tool. In the full scale model there would be over 2000 laminations, So i need to get the model to run and verify its validty on a small scale before i waste hours of solving time on a large stack.  I have created the bodies but when generating a mesh the generator just hangs. It worked fine for 1 lamination but now that there's 50 it doesn't get anywhere. It seams to get stuck at computing contacts.
There is a solid body in the centre of the rotor which i have created in order to put the pined constraint at its centre and apply the rotational body force to the rotor. This wouldn't be there in real life. The proportions of the hub and spokes are intentially thin and weak so as not to add too much stiffness to the model.
Do you have any suggestions on how i might simplify this to help it mesh and solve faster?
At a later date i would also like to model the epoxy resin inbetween the laminations of steel. I assume this would be simply a case of creating the material in inventor with the relavent properties and then make alternate layers of steel and glue?
Thanksundefined
JDMather
Exactly what are you analyzing for?  What do you want to know from the analysis?
I am looking at the stresses in the rotor. Its a high speed rotor so the hoop stresses are significant. An earlier analysis modeling the rotor as a solid body gave the result attached in the image. This is arguably not representative as i have lots of laminations and glue, not a solid body of steel.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
