Thicken feature Problem (DIRECTION)
gioia.emanuelex
Message 1 of 9
gioia.emanuelex
Good evening, I am currently doing design work from a reverse engineering process for mechanical parts.
Usually working in the Autodesk suit, the parts I am studying were developed in Solidworks.
The function I am writing for is "thicken", which in inventor allows to select a direction (even different from the one normal to the surface) (which obviously implies not being able to recreate the same component)
I can't find an equivalent in either Inventor 2023 or Fusion 360. Do you have any ideas?
PS.
I have attached three photos, where I show, the SURFACE on which to apply the thicken feature, the OBJECT with the direction selected (thus corrected), and the SOLID without having selected the direction (same result I get on inventor by not being able to select it).
Replies (8)
Message 2 of 9
JDMather
@gioia.emanuelex
Can you turn off the shadows in your SolidWorks screen captures - I am confused as to what you are after.
Can you Attach the *.sldprt and your attempt in Inventor *.ipt files?
If Inventor Thicken doesn't return the results you are after - then I am suspecting maybe Direct Edit will work.
Message 3 of 9
johnsonshiue
Hi! On Inventor or Fusion, Thicken/Offset work hand-in-hand. Only the face normal direction (+-) is allowed. The vertical protrusion can be done using either Extrude/Offset Start or Ruled Surface.
Many thanks!
Software Test Engineer
Message 4 of 9
gioia.emanuelex
I tried using "Ruled Surface" (on fusion) and actually, I got the desired result.
The problem that remains is how to fill the surface evenly in order to get a solid and not a surface.
I attached photos to represent:
-the surface I have to "extrude" following a direction (other than normal to the surface)
-the correctly machined surface (BUT THAT I MUST FILL UNIFORMLY)
-the application of the thicken command without selecting a direction which leads me to the wrong solid.
thanks for the help!
Message 5 of 9
gioia.emanuelex
To better explain the problem I will refer only to Fusion 360, with related photos.
I have a surface that I need to "extrude" to make a solid. The most consistent command would be "thicken," but the inability to choose a direction results in the wrong solid.
Solid that in Solidworks I can get very simply by choosing a direction other than normal to the surface.
Message 6 of 9
blandb
Can you utilize the vector ruled surface to move straight up, then boundary patch and sculpt or stitch the surfaces together?
Autodesk Certified Professional
Message 7 of 9
gioia.emanuelex
Thanks a lot!
It worked!
Message 8 of 9
johnsonshiue
Hi! Instead of using Boundary Patch as Brad suggested, you may simply pattern the surface vertically. Then stitch the surfaces.
Many thanks!
Message 9 of 9
xot_UFO
Hello. Is there still no plan to add this feature to fusion ? Every CAD software has it, it's vital for many workflows.
