Thicken doesn't show subtract option
SharkDesign
Mentor Mentor
Message 1 of 11
SharkDesign
Anybody know why the subtract option isn't available?
The first time I launch the thicken command, all the options are greyed out, but once I choose quilt and switch back to face they are all suddenly available.
The second time I launch the tool subtract is available.
Video:
Screencast will be displayed here after you click Post.
7ea358c9-524e-4eb0-82b2-91617fa8a615
  Inventor Certified Professional
Replies (10)
Message 2 of 11
TheCADWhisperer
Attach file here.
Obvious question, do you have something to subtract from?
Message 3 of 11
SharkDesign
Yep, happens on any file, but only the first time I launch the command. If I use the thicken command then start it again the options come up first time.
You can see in the video I posted.
Message 4 of 11
SharkDesign
Not sure if the screencast is showing for you, if not here it is again.
Message 5 of 11
torbjorn_heglum1
To remove material, I normally just change offset direction (below the distance textbox)
Torbjørn
Message 6 of 11
blandb
@torbjorn_heglum1
That works too!
But if you uncheck automatic blending, this the cut options appears...
Autodesk Certified Professional
Message 7 of 11
johnsonshiue
Hi! This confusion comes up from time to time. On Inventor 2012, there was an effort to make Thicken works more like a direct manipulating command operating on solid face. So, the default was changed to "Auto-blending" checked. This means the the face will in the face normal direction without new faces created.
To access other operation types, just uncheck "Auto-blending" option and all Thicken operation types will be available.
Many thanks!
Software Test Engineer
Message 8 of 11
SharkDesign
I've just gone to look at the tool again. What you say is right, but what is happening is that when I choose Quilt, Automatic Blending is unticked, when I switch back to Face, Automatic Blending is not turned back on so I still have access to the subtract command.
This is very confusing, but I don't really know how you'd fix that.
Automatically re-enabling the blending option would also confuse users because it would look like it was impossible to get subtract with the face option.
Message 9 of 11
johnsonshiue
Hi James,
I agree with you. The behavior was confusing. I cannot count how many similar questions about this that I had to reply to. It was not a well-thought-out design. We are modernizing Inventor UI and workflows. Hopefully, this kind of issues will be resolved soon.
Many thanks!
Message 10 of 11
Khoa_NguyenDang
Hi @johnsonshiue
That's great to see your explanation about this confusing problem of thicken feature in Inventor
I am writing code to create automatically solid for all faces that I selected
But with the part create from Make Component in Multi Solid Part. For the first time, I use my code for Thicken Feature. It shows the error.  I think the reason is from what you explain about Thicken
Have you had experience in code for thicken feature? If yes, hope you can help me
Thank you so much
Message 11 of 11
johnsonshiue
Hi! I know a little bit about iLogic. I am nowhere near an expert. The way I look at iLogic is that it is very close to doing something manually but in a more structured way. If you can do something manually in Inventor, chances are it can be done in iLogic (rule or VB.net code).
For this case, I suspect you will probably need to turn off "Auto-Blending" option in Thicken command (Inventor API) just like you do in manual workflow.
Many thanks!
