The system cannot open the device or file specified
I recently had to run a system restore on my pc due to something I goofed in the registry, and the rollback uninstalled autodesk inventor which I've only had on the device for a few days. When I try to reinstall inventor I get an error saying 'The system cannot open the device or file specified' (attachment 1). I then get sent to the homescreen on the installer client, and if I click install again I get a windows prompt saying 'The system cannot find the file specified. C:\Users\Jonathan\AppData\Local\Temp\_AIC991.tmp\x64\inventor\inventor.msi' (attachment 2)
I've used revo uninstaller to get rid of any stray autodesk software that may be giving the installer a headache, and I also cleared out the autodesk folder in appdata and neither of these appeared to help. I also don't have trend micro so that's not the issue. Installing a trial copy as was recommended on another thread didn't work either.
Any help would be much appreciated!
mdavis22569
Try the Virtual Agent:
https://forums.autodesk.com/t5/autodeskhelp/download-links-on-the-autodesk-virtual-agent/ba-p/509351...
if that doesn't work, might get a bit more help on the installation / Lic forum
http://forums.autodesk.com/t5/installation-licensing/bd-p/24
Mike Davis
Virtual agent did the trick. Thanks for the help!
How did you find the solution? Virtual agent can't even response to my query!!!
Mark.Lancaster
@Anonymous
This posting is about an installation problem.  You have a model issue and the Autodesk Virtual Agent has nothing to do with missing component files in a model.   The Virtual Agent is used to install the application.
Mark Lancaster
