The number of surfaces of my design.
Message 1 of 10
I want to run a EM simulation using asymptotic analysis. I need to get the number of surfaces of my design. Can I know how I can find it using Inventor 2020?
Replies (9)
Message 2 of 10
mcgyvr
Try pressing Ctrl + F7
Does that give you the info you need?
Give it some time if this is a large model...
Message 3 of 10
mmontes016
EMS is a 3D electromagnetic field simulator software suite, based on the powerful finite element method.
EMS is seamlessly integrated inside Autodesk® Inventor®.
The full integration in Inventor means that users will not need to import, export, heal, clean, or fix any geometrical inconsistency because they will be working right inside Inventor while optimizing their electromechanical design. This will allow our users to shorten their design cycle and get their product to the market quickly.
EMS targets four main areas: electromechanical, electromagnetics, power electronics, and electromagnetic behavior.
EMS empowers the designer to compute electric, magnetic, mechanical, and thermal parameters - including, force, torque, magnetic flux density, magnetic field, electric field, electric flux, current flow, eddy current, inductance, capacitance, resistance, flux linkage, core loss, saturation, induced voltage, force density, power loss, temperature, temperature gradient, heat flux and more.
EMS applications include: motors, generators, linear and rotational actuators, relays, MEMS, magnetic recording heads, magnetic levitation, solenoids, loud speakers, coils, permanent magnets, sensors, NDT, NDE, high power, high voltage, transformers, inverters, converters, bus bars, inductors, insulation studies, bushings, electrostatic discharge, electromagnetic shielding, EMI, EMC, medical devices, eddy current devices, fuses, circuit breakers, capacitors, etc.
Message 4 of 10
Thank you for the reply.
This can give the surface body. I got this for my design:
Total Bodies: 7308
Solid Bodies: 2436
Surf Bodies: 2436
Other Bodies: 2436
Checked Bodies: 224
But that is not the total number of surfaces. I tested it with a simple solid cube. I got this results.
Total Bodies: 0
Solid Bodies: 0
Surf Bodies: 0
Other Bodies: 0
Checked Bodies: 1
But the total number of surfaces should be 6 for solid cube.
I really appreciate any help.
Message 5 of 10
mmontes016
why do you need to know the total number of surfaces??
Message 6 of 10
The EM Simulator (Wireless InSite) is using Ray tracing method. It has a limitation that we can not have more than 80K surfaces. So I want to check the number of surface before I calculated it using the EM Simulator (It is taking long time to calculate it).
I know you send some information about EMS. It looks like that EMS is using FEM. I am simulating 1720mmX1650mmX1220mm chamber for 26.5GHz to 40GHz frequency range. I think that is not possible for this software.
Message 7 of 10
SBix26
In Inventor, a solid cube has six faces, no surfaces.  A surface cube still has six faces, but no solids.  Surfaces and solids are two different types of bodies that may be found in an Inventor model; both of them are made up of faces.
Sam B
Inventor Pro 2022 | Windows 10 Home 2004
LinkedIn
Message 8 of 10
I am new to Autodesk Inventor. Probably, this is very fundamental.
I found this article : Quick Detection of Model Size with Check Design - IMAGINiT Manufacturing Solutions Blog (rand.com)
But this article was posted in 2012. Could I know How I can get the Check Design in Inventor 2020?
Message 9 of 10
Message 10 of 10
johnsonshiue
Hi! I believe Design Checker is an Inventor Add-In free to all subscribers. There are a few other checking tools on App Store. Please take a look.
https://apps.autodesk.com/INVNTOR/en/List/Search?isAppSearch=True&searchboxstore=INVNTOR&facet=&coll...
Many thanks!
Software Test Engineer
