Hello, I have a Template for my IPTs, where the first created sketch is named "Sketch2" (then "Sketch3", "Sketch4" and so on). Probably it's because I created a sketch in this template and delete it.
But how to reset sketch counting? I'd like to start my models with "Sketch1".
It happens because you have (at some point) created a part file, then a sketch (Sketch1), then deleted that sketch and saved the part as your template. Hence you always start with "Sketch2".
Either:
Thank you, for confirmation of my hypothesis.
Copying a blank template is no solution for me. There is too much changes in my template.
Unfortunately no.
My problem is this:
This is actually an on-going problem that has been around for over 20 years. Autodesk doesn't seem to have any plans on "fixing" this. If I were in your shoes, I would do whatever it takes to get back to "sketch1". Even if it means redoing your template.
There is a post on the Idea station if you want to vote for it.
Kirk
I think you could copy almost everything from your existing template into a new one. Certainly all iLogic rules, styles, sketch blocks; parameters and iProperties, too. What else would be a problem to transfer to a new, blank template?
Sam B
Inventor Pro 2023 | Windows 10 Home 21H2
