The extrusion of a custom font fails.
frankstardelux
frankstardelux
I have created a custom font which contains my company's logo. When I attempt to extrude this, it fails. Error message appears:
Create extruded feature failed
         The attempted operation did not produce a meaningful result. Try with different inputs.
In an attempt to find the issue, I split the logo into 3 parts. To my amazement, each of these will extrude fine. I've spent a huge amount of time on this and I'm convinced that Inventor has a bug. Reading around this subject, it is clear that a bad path or loop somewhere in the logo could cause Inventor to fail the extrusion but if the 3 parts will successfully extrude on their own, then I don't understand why it fails together. Nevertheless, I've been through the loops with a fine tooth comb.
The logo is saved as a svg file and I've create 3 more svg's for the 3 areas of the logo. This was done using the free software: Inkscape. Each of these is a "letter" within a font (see below). The font is assembled using https://glyphter.com/ which allows you to download the font ready for installing. The svg's and font install files are all attached in a zip. Inkscape also has a function to Simplify a shape without changing it too much. I've used this too without success.
A - Complete Logo after using Simplified tool
B - Just the roundel
C - Text: "Laser Quantum"
D - Text: "A Novanta Company"
E - Complete logo
To replicate what I'm seeing, download and unzip the files and install the font by R-clicking on Glyphter.tff and choosing Install. Then create a sketch and add some text. Type the letter B, C or D and change the font to Glyphter. Then extrude. This should be successful. Then edit the sketch and change the letter to A or E. This should then fail. To clarify, B, C and D and sub components of E. That is B + C + D = E. Whereas A is the simplified version of E.
johnsonshiue
Hi! I have trouble installing the font on my machine. I am getting some weird text. Regardless, I have see font-specific profile issue. This is about the ability to "convert" text to sketch geometry as a profile. Inventor generally supports true-type fonts but the profiles may not be properly converted.
Are you trying to extrude the text in this font as a solid body?
Many thanks!
Software Test Engineer
frankstardelux
Hi Johnson,
Below is the image you should see when you type the letter A (must be capital) and the font selected is Glyphter.
I just don't understand how Inventor can successfully extrude the 3 parts individually but fails when they're together. When I exported the SVG files, I deliberately didn't change anything so I could test which part contained the error and non of them do as shown by the image below.
johnsonshiue
Hi! I guess the profile conversion algorithm does not like the font with multiple rows of text. I could be wrong but I have never seen a font like this. I will work with project team to understand the behavior better.
Many thanks!
doug.johnston
Have you tried the emboss feature to see if the same issue occurs ???
I have found that "some" custom / downloaded fonts do not extrude.  Most of the time I just "trace" the fonts in a sketch and extrude from that sketch.  It takes longer, but sometimes it's the only way I can reproduce that fonts.
It's not easy maintaining this level of insanity !!!!!
johnsonshiue
Hi Doug,
The process of recognizing profiles in Extrude is the same as the one in Emboss or other sketch-based features. I don't think it will work for Emboss either.
Many thanks!
