TEXT SIZE ADJUSTMENT
hi guys,
I am using Inventor Profeesional on windows 7 ans  working on a project. In it i want to  write an alphabet 'A' that gets exactly fill inside a box 1.3 cm* 2cm dimension rectangular box. Is it possible that i can adjust both height and width of alphabet so that it completely get fit into my 1.3cm * 2cm box
Thanks.
SBix26
Yes. But what version of Inventor are you using with Windows 7?  If it's a really old version of Inventor, you will have trouble finding anyone to create a model that you can open.
Sam B
Inventor Pro 2022.0.1 | Windows 10 Home 20H2
LinkedIn
SharkDesign
You can do what you like.
If it's just one piece of text you can double click or right click edit the text and change the font size.
If you want it like that every time you need to create a style.
Then you either go into other parts of the style editor to add it to dimension styles etc or you can just use that text style on text notes that you create in the drawing.
If it still doesn't show up right, check you are using the right style by clicking the text once to select it, then looking here:
  Inventor Certified Professional
