Text in exported PDF is not as "whole" text
ReneRepina
ReneRepina
Hello.
When we export to PDF and we have some texts included, they are not exported as "whole" texts.
To give you an example:
Our Documentation department exports our drawings to PDF. Then they want to "edit" them in CorelDRAW, but every letter in text is as single symbol, not as "whole" text to "edit".
When using "print" option and exporting via "PDFCreator", it works OK.
Is normal PDF export limited to such actions?
Can we change any setting to fix that?
P.S.:
We want to use "normal" export, because we are exporting it via iLogic.
Best regards,
Rene Repina
ReneRepina
Hello @Gabriel_Watson .
Probably not, because there is a "PDF  Translator" implemented inside Inventor / iLogic, nothing else, at least what I am aware of.
Do you have any suggestion on how to try it with "CutePDF", if even possible?
I have checked the suggested links. If I remember correctly, we do not have a problem with letters not being letters, but the whole text is splitted into single letter, so basically it should be 1 text box, but there are actually several text boxes, but with single letters.
I did more digging around and found next links. It seems that they should work calling Print Manager via iLogic. I will test it soon.
Links:
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/print-to-pdf-with-ilogic/td-p/816400...
https://forums.autodesk.com/t5/inventor-forum/font-bar-code-dwg-to-pdf/td-p/5514508
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/printing-to-pdf-ilogic-using-printma...
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/c-print-to-pdf-without-pdf-addin-sav...
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/printing-to-pdf-using-api/td-p/75833...
ReneRepina
Hello.
I did the testing and opened a case with Autodesk. It seems it is either a bug or a limitation to this. More information about the progress is going to be on below article link.
Article link:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/After-exporting-th...
Best regards,
Rene Repina
