Text Disappears when editing revision block in Inventor 2018
jweiss1313
Message 1 of 8
jweiss1313
We just recently upgraded to Inventor Professional 2018.1.  When we try to edit text in a revision block, all the existing text to the right of the cursor disappears.  I'm seeing this issue in every install.
Workflow.  Edit revision block.  Place cursor where you want to edit the revision block text and all existing text to the right of the cursor disappears.  This is not good.
See the attached screen capture where I'm trying to edit the text.  Notice that that everything to the right of the number "1" I placed in the text disappeared.  All I want to do is insert some text.  Inventor is assuming I want to replace everything to the right of the cursor.
Please help to solve issue/bug.  Thank!
John C Weiss Jr.
CAD Manager
Follett LLC.
Replies (7)
Message 2 of 8
johnsonshiue
Hi John,
This is a known issue on 2018 RTM build. It has been fixed in subsequent updates. Could you install 2018.1 Update at least?
Many thanks!
Software Test Engineer
Message 3 of 8
jweiss1313
We are already running Inventor 2018.1 so the problem still exists.  We will wait for a fix to be announced.  Thanks!
John C Weiss Jr.
CAD Manager
Follett LLC.
Message 4 of 8
johnsonshiue
Hi John,
Sorry for my bad memory! The issue was fixed as of 2018.1.1 Update. 2018.1.2 is available also.
https://knowledge.autodesk.com/sites/default/files/file_downloads/INV22120_enu.htm
Many thanks!
Message 5 of 8
Mark.Lancaster
@jweiss1313
John..  Have you installed Inventor 2018.1.2?
Mark Lancaster
Message 6 of 8
jweiss1313
Hi Mark,
This is a funny story.  I originally did install update 2018.1.2,  but we were all having right mouse clicking issues with the marking menu.  I uninstalled 2018.1.2 and when back to 2018.1 and the right mouse click issue went away.  I decided to change my deployment to install 2018.1 for the remainder of my upgrades.  So this is a story or which bug is a bigger pain.  We have had our hand full of bugs with our Inventor 2018 upgrades.  I'm hoping that update 2018.2 fixes them all.  LOL!
John C Weiss Jr.
CAD Manager
Follett LLC.
Message 7 of 8
johnsonshiue
Hi John,
The right-click issue can be avoided if you turn off Marking Menu. Go to View -> User Interface -> uncheck Marking Menu.
Many thanks!
Message 8 of 8
jweiss1313
We all use the marking menu a lot and would prefer not to turn it off.  I think we are going to wait for the next update and hope that it fixes both the disappearing text and the marking menu issue.
Thanks for your help!
John C Weiss Jr.
CAD Manager
Follett LLC.
