Hi
how to get a tension spring model from Assy environment > Spring features ?
or do we need to draw manually ?
Solved by JDMather. Go to Solution.
If you don't find a suitable model at grabcad.com or similar places you must model it yourself.
Jürgen Palme
Springs are created on the Design tab in assembly.
Of course you can always model the geometry manually.
