Template name do not change
Hi!
Se attached picture. I have made a red cirkle araound the name of the template (Nexans).
In the saved standard template (idw-file) that is used in this picture, have a different name than Nexans  in the red cirkle. But when I open a new drawing it says Nexans as you can see. Why do not the name of the template change when I cahnge it in the template-file?
mdavis22569
Can you share the idw ?
Mike Davis
Cadmanto
That is your title block name, not the file name.  That is going to always be what ever you named in in your template.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
blandb
Just to be clear, in your template file, you have changed the title block to a different title block other than "Nexans", saved it, but when you start a new drawing from that template it brings back the "Nexans" title block instead of your new on you set?
Autodesk Certified Professional
johnsonshiue
Hi! To help us understand the issue better, please share the idw template file.
Many thanks!
Software Test Engineer
Sorry!
