Template 3D PDF edit
If it´s possible to change a 3D PDF?
    - costumize color from template;
    - costumize icon
Mark.Lancaster
@Anonymous
Welcome to the community..
It is but I don't think its that straight forward..  I will tag @mdavis22569 and @mcgyvr since they have been working on this and they can give you more info.   Also have you updated to Inventor 2017 SP1?  Certain 3DPDF issues were resolved in that update.
Mark Lancaster
mdavis22569
Yes you can modify them ...
Colors in what way?
You'd need a some type of Adobe PDF editor. I have Adobe DC.
I have a few different tips on my youtube...for how to edit the part number quantity and things like that.
Colors are an issue, depending on how you want to do them. Currently they (Autodesk/Anark) are working on getting the colors to come through and the glass to be transparent.  Right now black doesn't come thru.
I'll help you where I can, and share some of my custom templates.  Make sure you have the newest ones that came with the SP1 / R2 update. They allow the color and smaller pdf sizes.
Mike Davis
mdavis22569
current template
as you can see in the 3d pdf image ..it doesn't show texture/surface effects of a material in the 3d pdf yet either ....
Mike Davis
kennyj
To help anyone who has the new Adobe DC Pro - using "edit" when the pdf template is open won't give you all the fields to change (especially the icon area).
Instead, close out of the PDF Template.  Then right click on the file and instead of "Open with Adobe DC Pro", choose the option further down that says "Edit with Adobe DC Pro"; this option gives you the full template and fields to edit, including the logo area.
Hope that helps!
Kenny
anthony.ravello
I saw a Video from you with PDF 3D
Can u share please ur Templates?
There is a tutorial how to customize a PDF 3D?
johnsonshiue
Hi! Here is the Help page describing the workflows.
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Inve...
Many thanks!
Software Test Engineer
