Tapered Bevel Edge
Tapered Bevel Edge
Tapered Bevel Edge
How would I achieve a transition from a 2.5mm bevel on the length to a 1.5mm bevel on the width?
blandb
Is the image below what you are trying to achieve?
When you say "Bevel" do you mean chamfer or fillet?
The above image was created with a variable fillet.
Autodesk Certified Professional
SBix26
Attach your attempt here and tell us what version of Inventor you're using, along with the answer to @blandb's question.
Also, a hint for easier forum communication: you can embed your images directly in the text by using the camera icon in the toolbar.  That makes it quicker for those of us reading to be able to see the images directly rather than previewing attachments.
Sam B
Inventor Pro 2021.1.1 | Windows 10 Home 2004
LinkedIn
Thank you that was what I was looking for. I came from Blender and there to make a chamfer or fillet the tool was just called bevel.
