Tanker Truck and Rail Car Correct Models
Message 1 of 8
I am doing a research project about loading/unloading on Tanker Trucks and Rail Cars. Does anyone have models that are dimensioned correctly for the United States? I am mainly talking about the location of the loading and unloading ports for the trucks and rail cars. If anyone has such models they would be greatly appreciated or if anyone could direct me to where I could find some.
Thank you in advance.
Replies (7)
Message 2 of 8
Mark.Lancaster
@Anonymous
I would at least start here https://grabcad.com/library
Mark Lancaster
Message 3 of 8
Cadmanto
What kind of railcars?  Gondola, flat or box?
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 4 of 8
swalton
There are many different types and sizes of rail cars and tanker trucks.  What specifically are you interested in?
My experience retrofitting rail cars is that each manufacturer and initial purchaser makes slight changes in car geometry.  About the only thing that is consistent is the coupler height, truck size, and overall width to meet specific Interchange requirements.  The American Association of Railroads has several books on design requirements that may be helpful.
I expect that there are Federal DOT regulations on the tanker trucks, but I doubt that there is a common interface standard among manufacturers.
You may have better luck contacting specific manufacturers and asking for drawings/models.
Steve Walton
Inventor 2025
Vault Professional 2025
Message 5 of 8
Cadmanto
Don't know much about the tanker trucks, but a little about the railcars.  Depending on the type will speak to the load.
What has already been mentioned regarding specs, AAR has some specs online.
Checkout these links.
https://www.turbosquid.com/Search/3D-Models/railcar
https://www.turbosquid.com/3d-model/railcar
https://www.cgtrader.com/free-3d-models/train
Inventor Pro 2018
Best Regards,
Scott McFadden
Message 6 of 8
I was just given an update relating to what I am supposed to find.
18 Wheeler Truck Tanks
- Petroleum Trailer Tank . 4 or 5 compartments. Bottom (central right side) loading. US DOT 406
- Diesel Trailer Tank. 4 or 5 compartments. Top loading
- General purpose chemical trailer tank (not insulated "lagged") Single compartment top loading
- General purpose chemical trailer tank (not insulated "lagged") Single compartment bottom (rear) loading
- General purpose chemical trailer tank (lagged) Single compartment top loading
- General purpose chemical trailer tank (lagged) Single compartment bottom (rear) loading
- LPG trailer tank. Single compartment, bottom loading central mid
- Cryogenic trailer tank. Single compartment, bottom rear connections
- Dry Bulk (powder) trailer tank, top loading, single manhole
- Dry Bulk (powder) trailer tank, top loading, double manhole
- Dry Bulk (powder) trailer tank, top loading, triple manhole
Rigid 4x4 wheelers and 4x6 wheelers
- Fuel Oil Tanker, 4-5 compartment, bottom loading
- Fuel Oil Tanker, 4-5 compartment, top loading
- LPG "Bobtail", single compartment, bottom rear loading
If anyone has models of this, it would be greatly appreciated. I need accurate models depicting where the loading and unloading ports are at.
Message 7 of 8
ToddHarris7556
+1 for the comments already offered : I'm not aware that there's a 'National Standard' for either rail or trailer.
I haven't done a *ton*, but in 6 or 8 rail loading facilities, and maybe 20 truck loading facilities, there's a lot of variation. Manufacturers may offer some standard designs, but my understanding is that they're most often customized to meet specific material needs - flow/viscosity/abrasion/wear/material compatability/etc. There are so many variations, I'm not sure it would be practical to have national standards.
I may be wrong - not a logistics expert, just a process plant guy 🙂
Todd
Product Design Collection (Inventor Pro, 3DSMax, HSMWorks)
Fusion 360 / Fusion Team
Message 8 of 8
Scott,
I reached out and found the exact kinds of rail cars and tanker trucks they were asking about.
Anything helps, Thanks!
David Evan McDonald
The Citadel, The Military College of South Carolina
Mechanical Engineer
Mike Class of 2020
