System configuration root element missing
Message 1 of 10
Hi all, I got an error message the other day
Anyone know of a fix to this
Inventor is acting a little weird since this error showed up also
Windows 10, 64
inventor professional 2017
Replies (9)
Message 2 of 10
johnsonshiue
Hi Chris,
Do you know what Inventor 2017 build you are on? Go to Help -> About. Go to Inventor Install files and run  \Setup\x64\LWS\AutodeskDesktopConnect.msi
Many thanks!
Software Test Engineer
Message 3 of 10
Hi Johnson
Im on product design suite ultimate
Message 4 of 10
johnsonshiue
Hi Chris,
I still need to know what exact build of Inventor Professional 2017 you are running. Please start Inventor and go to Help -> About.
Many thanks!
Message 5 of 10
Hi
your going to have to be more specific where this file is located thx
Message 6 of 10
johnsonshiue
Hi Chris,
It is not in a file. It is in a dialog. Start up Inventor and find Help menu (with a question mark) on the far right -> click on About. It will show the build number of Inventor you are running.
Many thanks!
Message 7 of 10
Message 8 of 10
salariua
@Anonymous
Do a backup of your Application Options and User Customization and use the reset utility:
Here is a full description on how to do the above and the download link
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-use-Inventor-Reset-Utility-to-reset-the-local-environment-for-a-Windows-User-Account-Inventor.html
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Message 9 of 10
DannyHubbard
Chris,
My first thought would be some kind of corrupt of this config file. I would go to the folder "C:\Users\Chris Garneau\AppData\Roaming\Autodesk\Inventor 2017\" delete the file InventorConnectUIConfiguration.config then restart Inventor.
This file stores the location and sizes of the Connected Design dialogs and panels on the screen, when deleted they will go back to the default and the config file will be recreated.
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Message 10 of 10
Hi Danny
Thx for that info, it works fine now so far
No troubles at launching inventor
