Symbols next to part names in assembly tree
mattKKSX3
Message 1 of 10
mattKKSX3
I have no idea what these little symbols are or how to reference them? HALLLP!!!!
Replies (9)
Message 2 of 10
mattKKSX3
I have checked the help files to no avail on these symbols
Message 3 of 10
skyngu
Message 4 of 10
mattKKSX3
Thats the ticket!!!! Thank you!
Message 5 of 10
johnsonshiue
Hi Matt,
The little dot is the fully constrained symbol. When the dot is solid (dark), it means the component is fully constrained. When it is empty, it means there is still degree of freedom left. Go to Tools -> App Options -> Assembly -> check "Enable redundant relationship analysis." With this option on, the dot status will be more persistent.
Many thanks!
Software Test Engineer
Message 6 of 10
Found this link helpful in addition to @johnsonshiue reply
Inventor 2022 Help | Constraints Enhancements | Autodesk
Message 7 of 10
PaulPink1017
This explains what the constraint symbols mean. This is great.
What does the blue dot with an exclamation mark in it mean??
Message 8 of 10
johnsonshiue
Hi Paul,
It usually means some sort of warning. You could move mouse cursor to the sign and the tooltip should reveal it. Please feel free to share a screenshot or the files that exhibit the behavior.
Many thanks!
Message 9 of 10
New_to_Inventor
Hi @johnsonshiue - Is there some sort of list or cheat sheet for Autodesk Inventor glyphs??
Being new to the software, every time a new symbol pops up, I have to stop and search the forums (time consuming) to find out what is happening in the model.
For example, this yellow check box- I can't find it on Google and the representation seems to be locked - I can't tell if they're related.
Message 10 of 10
mattKKSX3
I believe that means that the Checked representation is the selected one, according to this quick glance tutorial i found. i didnt realize you could do different representations like that as i never really had the need except one time, and i barely started using inventor around then. Great find, thank you!!
https://www.engineering.com/autodesk-inventor-tutorial-positional-representations/
