Switching Componets in a drawing
I have a drawing which was created from an assembly. Whomever, created the drawing dimensioned the assembly as a detail part. It has a considerable amount of dimesioning which I don't want to recreate. It it possible to do a save as on the drawing and then swap out the assembly .iam for the detail part .ipt which should have been there intitially? I have tried use "Change Model Reference" under the Manage tab but it only looks for a replacement assembly and nothing else.
Any help would be greatly appreciated.
Dale Bennett
Trapeze Group
Cedar Rapids, Iowa
SBix26
I don't believe that this is possible.  All the methods for accomplishing this assume the same file type.  I'm afraid that you will end up re-creating the annotations.
Sam B
Inventor Professional 2016 R3 SP1 Update 1
Vault Basic 2016 SP1
Windows 7 Enterprise 64-bit, SP1
tschaeferZNBXX
Change Model Reference would work if and only if the part is in the same orientation as the assembly.  The X, Y and Z axis' must be the same along with the faces (Front, Back, Top, Bottom, Left and Right).  You may still have to do a little clean up but not nearly what you would if you started from scratch.
Thomas "Matt" Schaefer
Engineering Tooling and Vault Manager for Material Handling Systems MHS
*AU Speaker 2018*
* AU Speaker 2017 *
Please use the "Accept as Solution" and "Give Kudos" functions as appropriate to further enhance the value of these forums.
If it's not totally disruptive to your file management, the cheap work around is to create a new assembly with only the one part in it, and then do the replace.
Whoops, beaten to it.
Thanks for the suggestions, but it looks like I will have to bite bullet and create a new drawing with the correct .ipt the way it should have been done initally.
