Hello
I'm having a problem with a sweeping feature right now that I've never had before.
I'm trying to sweep some sort of rectangular spiral along a cylinder. The path is made up of about 40-50 individual lines created using a 2D and a 3D sketch. When I start selecting the first few lines for the path, everything works fine. The more lines I select, the longer the calculation takes. And extremely exponentially.
10 lines = 1 second
20 lines = 100 seconds
30 lines = 1,000 seconds
40 lines = you don't want to wait.
And what's really weird is that the calculation also increases exponentially with the length of the shape.
Same number of lines, but if you increase just one dimension (See picture X) from 100mm to 1,000mm, it's almost impossible to calculate.
See attachment.
Any idea how to fix?
Thanks and regards
Ben
