Sweep using 3D Sketches fails on saving
CJ.10E-10mm
CJ.10E-10mm
I am endeavouring to create a sweep profile that enables the creation of a 3D model that I can subsequently slice and 3D print without overhangs. My part is too small to allow the slicing software to add supports.
The sweep option readily creates a model that looks useable but repeatedly fails when I try to save it.
I have checked every aspect of my part creation.
Using a rail as a guide, a 360-degree profile rather than the complete loop is generated that can be saved. If I use the surface on which my 3D sketch is created as the guide, it produces the part I require as per the image but fails upon saving
Does anyone have experience using 3D sketches that can offer advice?
The part is commercially sensitive.
Thank you.
Replies (8)
CJ.10E-10mm
I have managed to overcome the problem by chopping the 3D Sketch up into 360-degree loops. It is not ideal, but I must assume from the lack of replies I am venturing into an are unfamiliar to many.
blandb
Can you share your file?
Autodesk Certified Professional
johnsonshiue
Hi! The behavior sounds wrong to me. It could be geometry specific. Please share the ipt file here. I would like to understand it better.
Many thanks!
Software Test Engineer
CJ.10E-10mm
As the design is extremely commercially sensitive I have recreated a similar situation in a small file.
The sweep path, the guides and the sketch are all fixed.
The problem I have is the cross-section of the profile reverses as it travels 180 degrees.
I have had to split the sweep path allowing the upper and lower sections to overlap. As I have multiple sweep paths it has become somewhat complicated.
Thank you for your kind attention.
johnsonshiue
Hi! Many thanks for sharing the part! How do I reproduce the Not Saving issue?
Thanks again!
CJ.10E-10mm
*Good morning,*
I am unclear what it is, that you would like to know.
Are you asking how I created my model using the Sweep option with a Guide?
I will be willing to assist you once I have a clear understanding.
You will appreciate my design is quite complex and very commercially
sensitive, aside from the numerous attempts on my life.
I started work on the original design over six years ago.
My current design exceeds all of my expectations.
Christopher
johnsonshiue
Hi Christopher,
I am sorry I don't think I understand the error here. You said "3D Sketches fail on saving." Does it mean you get an error message when saving the file? I am not seeing that error. This is why I am asking how I can see the error.
Many thanks!
CJ.10E-10mm
Good morning.
When I performed a Sweep and pressed OK, it would fail to save.
I could see the effects of the swept profile, but it would collapse when pressing OK to save.
I rebuilt a new file and the error disappeared. Then Sweep functions worked beautifully without Inventor crashing.
I can only think I had corruption in my files.
If anyone reports the same error, I would suggest they rebuild their file from scratch.
I hope this helps to clarify the situation for you.
Christopher
