Sweep not working
Sweep not working
gert-leonvanlier
Sweep not working
gert-leonvanlier
See attached file: I am trying to create a weep of Sketch55 along 3D Sketch2, but as soon as I select the path Inventor is taking forever and eventually I have to close Inventor. I tried several times. Is there anything I am doing wrong?
JDMather
Is there a logical reason that you used Splines in your 3D sketch rather than Arcs or Bends?
Edit:  In 15+ years of using Inventor I have used a Fixed constraint maybe twice.
Why are  you using Fixed constraints - I do not see a logical purpose in this design?
gert-leonvanlier
At first I couldn't get arcs to work (tangent). I fixed that already, but still the sweep is not going well.
gert-leonvanlier
Well, I'm alway there, but I can't get this point to work:
When I pick the line after the arc, the sweep is not working anymore. Any ideas?
The same goes here. When I pick the path, the preview is fine, but then the message "The attempted operation did not produce a meaningful result. Try with different inputs."
gert-leonvanlier
Appearantly this was not working. I eventually first laid out the track in a 2d sketch, projected the lines on to several planes in a 3d sketch and connected the inclines from there.
johnsonshiue
Hi Guys,
Just to provide some update, this issue has been reported as INVGEN-30392. This is a bug. It should never hang.
Many thanks!
Software Test Engineer
