Sweep does not work
Sweep does not work
yta10
Sweep does not work
yta10
Hi
In assembly, I wanted to create new part using the sweep command. I drew lines using 3D sketch, but it says i can't use the sweep command. Could you please help me out ?
Thank you!
Sergio.D.Suárez
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
johnsonshiue
Hi! Indeed, like Sergio mentioned here, you need to have a 2D profile and a path to sweep. The image and the error message indicate the profile is missing. Please create a circular profile (a circle or projecting the tube face from another part).
Many thanks!
Software Test Engineer
yta10
Thank you! Your solution worked. I should have had more coffee this morning. I totally forgot to draw a profile.
yta10
Thank you for your answer! It helped!
