SWEEP CUT USING GUIDE SURFACE
bhenderson
bhenderson
Gday. I'm looking for input why this Sweep Cut using a 3D sketch helix & a guide surface doesn't work. See attached IPT file. Sketch6 is the cut shape, Sketch8 is a flat plane cut path & 3DSketch4 is Sketch8 wrapped around the surface.
I need to use the guide surface to ensure the cut stands up straight and doesn't lay over.
PDMC 2021
Inventor Build 353 Release 2021.3.3
Vault Pro 2021 Build 26.2.24.0, 2021.2.1 Update
SharkDesign
What happens if you make a much bigger helix to meet the top of your surface and use that as a guide rail?
  Inventor Certified Professional
bhenderson
I tried it for the 13th time and it's worked. All I can say is I changed the order of settings (previously worked from top down but this time changed that up) and it now sweeps. Odd!
PDMC 2021
