Hello all, I hope you can help.
I would like to create a feed scroll. I know this can be done in solidworks (see link). But can this be done in inventor.
The Image is similar to what I'm after, but my thoughts are that this is not possible in Inventor... yet. Am I Right?
The Solid in the image wascreated as a rectangular pattern (1200-off) of a cylinder along a helix path that is then cut from the work piece. In essence this is exactly what im after but as you can see there are far too many surfaces and the resultant cut is jagged especially when viewed with the shaded with edges style not to mention its size the file size 11+ Mb and hence i cant attach it to this post.
Is my method the only method available out there at the moment or am I missing a trick?
