Surface wont preview when constraining
radithya.rayhanadhya
Hello, need a help here.
In assembly we usually get a preview of surface (or axis) selection which we're going to constrain. But now i dont get those previews so its bugging me when i want to constrain some complex geometries. Is there any settings that i have turned off/on unconsciously?ssconstraintproblem.png
 In this picture my pointer is actually placed on the inner side of the big hole because i want to set constraint to the axis but i dont see any axis selection.
Alexander_Chernikov
Hi, Your preview mode is disabled (glasses)
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
tried that, didn't work 😞
blandb
Glasses do nothing more than show the object move into position for the constrain. If you are referring to the actual surface highlighting prior to selecting, but will show once the edge or surface is clicked. Then check to see if you have cycled your "Enable Prehighlight" setting.
Autodesk Certified Professional
i believe thats the one, thank you. just used the reset utilty 30 min before your answer hahah, but anyway thanks
