I was trying to create a canoe using surface modelling. When I was trying to create a LOFT, it pops-up an error message.
What does the message mean? And how do I solve the issue. I am goint to attach the .ipt on 2012 ver.
Hi @Anonymous
It works well for me using loft feature with these parameters :
It works also with surface feature.
What is your error message ?
Have you set the same parameters than me ?
Thomas
Mechanical Designer / Inventor Professionnal 2025
Which error are you getting?
I have tried to do the loft and I can do it:
Gilberto Binga
Engenheiro Mecânico - Engenheiro Mecatrônico
deLearning - YouTube Channel
Facebook | LinkedIn
LOUCO POR AUTODESK
A resposta resolve seu problema? Ajude outros usuários marcando "Aceitar como Solução"
Does the answer solve your problem? Help others checking "Accept as Solution"
Curtidas são apreciadas caso tenha gostado da informação
Likes are appreciated if you liked the information.
for those that are doing it ... are you in 2012? There have been some advancements since 2012 to the surface side of inventor...
What's the error that comes up?
