Surface modelling help
ImogenWright
ImogenWright
I have an STL file of a point cloud survey.
The four squares on this are cast-in plates.
I need to create a surface model of the geometry to assist with machining the face of a thicker plate which can be offered up to the existing.
CCarreiras
Hi!
This is an impracticable geometry to turn into a solid... too many faces to handle.
I would use the file only as a reference and design a new solid on top of this.
CCarreiras
johnsonshiue
Hi! I suggest you look into Fusion 360 Mesh Design environment. There are quite a few tools to help clean up the mesh and convert it to body geometry.
Many thanks!
Software Test Engineer
cadman777
A cost effective solution if you do it regularly.
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
