Inventor Forum
Surface (From STL) to solid
3 REPLIES 3
karl.zammit.18
1192 Views, 3 Replies
Hi, I it possible to convert an stl file to a solid in inventor? Or turn a surface directly into a solid?
3 REPLIES 3
mcgyvr
in reply to: karl.zammit.18
Yep.. You can convert a mesh STL file to a solid with this "Mesh Enabler"..
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=6950391119076900441&appLang=en&os=Win64
As for surface to solid there are functions like "Stitch" in Inventor already for that..
JDMather
I think you meant STEP (*.stp), not stl (a completely different file type).
If I do a section view there appears to be a non-manifold issue with this slot.
What version of Inventor did you say you are using?
If 2021 - examine the Attached file.
oh yep true. My bad. Thanks a lot
