you want to loft from the undended face to the dented position.
I think this would be best with surfaces:
1 - create the undented face (as a surface)
2 - offset this to the max depth of the dent
3 - create a sketch and draw the "start" and "end" of the dent - the edges where you want the dent to start to deform away from the original face and also the patch of the "fully dended" area
4 - use split face to remove the unwanted areas (inside the original face and outside the fully dented patch)
5 - use loft to go from the inside edges of the starting face to the outside edges of the dented patch - choose tangential conditions for both
6 - stitch all the surfaces together and then thicken the quilt to give you a solid.
alternative method #1: instead of having a dented patch/shape you can loft to a point (and have that tangential), depending on whether you want to control the shape of the dented patch.
alternative method #2: with 2015 (and I guess into the future), I guess you could probably use the direct/freeform modelling features. I've not got 2015 installed atm so I couldn't comment further.
I hope that makes sense - 2014 file attached.
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
