Announcements
Surface Bodies are not Shown in Derived Component
BeKirra
BeKirra
I notice all surface bodies are not shown in derived component.
Did I miss something?
Inventor 2023
Your helps are much appreciated.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
James_Willo
Hi, I'm having a similar issue, I can't turn on or off anything, not even solids.
I've asked Johnson to check it for me. Works perfectly fine in 2026 so might be a bug.
James W
Inventor UX Designer
James_Willo
Did you check Representation tab. Is a non-Primary Design View linked?
James W
BeKirra
Yes, it was in a non-primary view.
And thanks for your info.
Hope the earlier Inventor releases can be updated apart from 2025. 😀
X² + Y² = C²
James_Willo
This always catches me out because it's on a different tab. Hopefully we can redesign this dialogue one day and make it more obvious.
I think this will be the same on all versions. If the link checkbox is ticked, you are asking it to remain associative, i.e. it's always going to reflect the view you selected. This means you can't change the representation by turning geometry on or off.
James W
