Suppress Features when Flat Pattern Is Activated
ryan.robbins1
ryan.robbins1
I am attempting to find a way to have a "Bend Part" feature automatically be suppressed when the Flat Pattern is activated and then unsuppressed when switching back to the Folded Part.  I cannot upload an .ipt due to company policy.  I believe the only way to do this would be in Ilogic but am unable to figure it out.
johnsonshiue
Hi Ryan,
I am not sure if iLogic can do that. The issue here is that when Flat Pattern is activated, the focus has been shifted to Flat Pattern body (a dependent of the folded body). So, the Bend Part will need to be suppressed before Flat Pattern is active. I guess you will need to create  a rule that suppresses the Bend Part feature and then activate the Flat Pattern.
Many thanks!
Software Test Engineer
