Suggestion for improving the interface
andrei.gorbachev
Message 1 of 21
andrei.gorbachev
When you suppress dependencies in Browser, the icon turns gray. but in view of the fact that the icons are very small, this is not very informative. It's hard to see that addiction is suppressed. I propose to make the text strikethrough in parallel with this.
Replies (20)
Message 2 of 21
JDMather
Inventor Ideas - Autodesk Community
http://beta.autodesk.com
Message 3 of 21
andrei.gorbachev
I didn't understand what I mean
Message 4 of 21
mcgyvr
Neither do you. 🤔
Message 5 of 21
johnsonshiue
Hi! I think you may want to change the DPI (scaling) on your machine. Please go to Display Options -> change the scaling to a bigger value. The icons should look bigger.
Many thanks!
Software Test Engineer
Message 6 of 21
andrei.gorbachev
This does not work properly in Windows
Message 7 of 21
johnsonshiue
Hi! Do you mind elaborating what is not working? Please share a screenshot showing the problem.
Many thanks!
Message 8 of 21
andrei.gorbachev
Everything is working. But I don't like a lot about the way it is displayed.
Message 9 of 21
andrei.gorbachev
Do you see the first arrow? Do you think you can see her well? And the second one? can you see her? Me not? Is it very informative in your opinion?
Message 10 of 21
SBix26
Long time pet peeve.  Normal arrows for constraints are buried in the model and you have to zoom far out in order for them to appear so you know which way your constraints need to go.
Sam B
Inventor Pro 2022 | Windows 10 Home 2004
LinkedIn
Message 11 of 21
andrei.gorbachev
This is what we are talking about. Here's another example. Don't the developers understand this? Why do I need to do scaling every time when you can change the visualization of the interface? And I don’t know how to convey this idea to these lamers.
Message 12 of 21
johnsonshiue
Hi Andrei,
Many thanks for sharing the detail! I think I know the issues now. It is about the geometric glyph in assembly constraint, particularly when the model geometry is relatively big. The relative sizing of the direction arrow vs a vertex does not seem to be reasonable. At the moment, I am not aware of a way to control the size. It seems to be hard-coded.
I will work with the project team to understand it better.
Thanks again!
Message 13 of 21
andrei.gorbachev
There is also a problem with dimensions in the sketch. I have them quite complicated. And when applying dimensions, it is important that they stay where I placed them. And they did not run away from their seats when further editing and scaling the sketch
Message 14 of 21
andrei.gorbachev
Well, here's something else. Conflicting dependencies are not highlighted in any way. Well, here's something else. Conflicting dependencies are not highlighted in any way. Only the component is highlighted. And to understand what conflicts with what is impossible.
Message 15 of 21
andrei.gorbachev
If you are somehow connected with the developers, then it would be great to communicate not through this resource, but directly. I could make a lot of suggestions for improvement as I deal with the inventory from its fourth version.
Message 16 of 21
johnsonshiue
Hi Andrei,
I am the most senior QA member for Inventor team. I work closely with various project/product teams. It sounds like you have quite a few improvement suggestions to Inventor. Please feel free to sign up Inventor Feedback Community.
https://autode.sk/InventorBeta
There you can share you ideas with project team members and other community users. And, you can use the latest internal build on an install-free environment.
Many thanks!
Message 17 of 21
andrei.gorbachev
I understand that I am just a user of which there are many. But I am a user with a lot of experience. And for my 58 years I am tired of all bureaucracy. If the development team doesn't want to take these things into account, then I'm even less interested in knocking on a closed door. Good luck.
Message 18 of 21
johnsonshiue
Hi Andrei,
I am offering my best help. I am not sure where the negativity comes from. I can tell that you are unhappy with the status quo, probably other things too. However, I do appreciate your suggestions and insights.
I personally think the Inventor Feedback Community is the best place to further discuss requirements. We all can learn from each other.
Many thanks!
Message 19 of 21
andrei.gorbachev
Nothing personal. The pursuit of profit and mega corporations have killed more than one good idea. I know this from my own experience. But the effectiveness of your forum is very low for product improvement. Good luck again.
Message 20 of 21
SharkDesign
I'm an active member of the Beta forum and I have to say that they are brilliant. They listen to everyone's input, and whilst they don't always change the software to your liking, they do explain the reasons for it.
It's definitely worth a try.
I do also agree that a lot of ideas get 'archived' when they have large numbers of likes. This is probably due to it being a massive change in the software in order to achieve something small, but it would be nice for Autodesk say why something has been archived as it is quite disappointing when really obvious changes that need doing are archived.
  Inventor Certified Professional
