Inventor Forum
styles edits not saving
2 REPLIES 2
711 Views, 2 Replies
When I make changes through styles editor and try to save them, I get a window that pops up saying "Style library (C:\Vault_Work\Design Data) cannot be saved because it is damaged". Can anyone provide some insight and possible fix to this problem? Thanks in advance.
2 REPLIES 2
CCarreiras
CCarreiras
Hi!
Change your project to "Default" (or another USER Project).
Edit your project: In the "Use styles library", Right mouse button and select "Read - Write"
Save the project changes
Configure again the styles and save your changes.
In the end it's better to turn again the "Use styles Library " to  "Only - Read".
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Hi!
CCarreiras
yannick3
yannick3
Hi
the only way i found to avoid this error is to restore the design data and after open the idw, dwg, iam and ipt template and save style in library for each template. This allow to keep the change made in your styles
Yannick Verreault
INV PRO 2015
MS Office 2007
Win 7 pro, core i7 950, asus P6T WS
nvidia Gforce GTX 295
WD caviar black 500Go
WD caviar black 1To
Hi
Yannick Verreault
INV PRO 2015
MS Office 2007
WD caviar black 1To
