Style Manager - flashing list in active standard
NachoShaw
Advisor Advisor
NachoShaw
Hey @johnsonshiue
whats going with the Styles Manager / Hatches in 2022.2? When i activate the stadnard then select the hatch tab then click save, i get this in loop and the only way to get out of it is to kill inventor.....
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Gabriel_Watson
2022.2 here as well and everything is fine.
Try an Inventor repair maybe? Is your graphics card under Autodesk's compatible list, and updated with latest drivers?
Maybe grab the "hatch.xml" from another PC that does not have this problem, from the design data folder they're using. I'm attaching mine here.
NachoShaw
Hey
Thanks for the reply. Update:
Graphics are up to date
GPU is compatible
re-installed Inventor
re-installed 2022.2
the error only occurs AFTER i have clicked the button to get the 'From Style Library' button. Once that has been clicked and the materials have been imported, i get this error
Nacho
Gabriel_Watson
Is your style library placed in a network location? Try using a test project with local/default styles just to see if this happens again. Here I clicked the same button, as I said, and all was fine. Maybe try the compatibility hardware mode and software graphics just to be sure.
johnsonshiue
Hi! When dialogs misbehave, it could be DPI related. Try making the following changes.
1) Change Windows Screen Resolution and Scaling to Recommended setting.
2) Right-click on Inventor icon on desktop -> Properties -> Compatibility -> Change DPI Settings -> check both boxes.
Many thanks!
Software Test Engineer
