Inventor Forum
Style Libraries Read Only After Migration Inventor 2023
34 REPLIES 34
Message 1 of 35
gareth.butlerS9R7M
1563 Views, 34 Replies
gareth.butlerS9R7M
Hi All,
Have recently installed Inventor Professional 2023 and have used Style Library Manager to migrate the various standards.
All projects have their styles in 'Read/Write' state.
After migration I now have both the source and destination libraries in 'Read-Only' state. Please see below.
I know of the specific XML style file overwrite in previous versions, but replacing the 'Inventor Studio Lighting' and 'Lighting' XML' files have not worked.
Any help to resolve greatly appreciated,
Many thanks,
Gareth
Hi All,
Many thanks,
Gareth
34 REPLIES 34
Message 2 of 35
jhackney1972
I can confirm this issue.  @ChrisMitchell01 have you heard about this?
John Hackney, Retired
Message 3 of 35
BDCollett
Confirmed bug.
See the reply here from Johnson. 2022 had a similar issue, hence the discussion started then.
Solved: Re: Inventor 2022 style library is Read-Only after saving styles from file - Page 2 - Autode...
Confirmed bug.
Message 4 of 35
gareth.butlerS9R7M
Many thanks for the replies, seems like it might be best to wait for a fix from Autodesk. That will teach me to get excited for new features and update on or near release day! 🤣
Message 5 of 35
ChrisMitchell01
Yes, this was unfortunate. It was only reported against the 2023 Inventor Beta on the same day as it was posted here. I  just see today that a fix is now being tested.
Chris
Chris Mitchell
PDMS Customer Engagment Team
Chris
Chris Mitchell
Message 6 of 35
johnsonshiue
Hi! I am sorry that the issue repeats in 2023 unfortunately. This time is due to incorrect Weld style version. If you cannot wait for the fix, you may perform the following steps.
Close Inventor and go to File Explorer.
C:\Program Files\Autodesk\Inventor 2023\Bin\_NewStylesLibrary\Weld.xml
Edit the file in Notepad and change the version from 3 to 4. Save the change.
Many thanks!
Software Test Engineer
Many thanks!
Message 7 of 35
gareth.butlerS9R7M
Hi Johnson,
Many thanks for investigating this for me, I followed your steps and all the libraries are working again and are no longer read-only.
No need to be sorry, this is complex software and there will be occasional bugs in the pursuit of product advancement. 😀
Hi Johnson,
Message 8 of 35
gareth.butlerS9R7M
Hi All,
I thought all was fixed until I opened a new mm part file and got the messages pictured below.
I have checked the various .xml files and they appear to reference the (ANSI-mm) standard.
Maybe there is something I have missed?
'R:/3. Inventor Design Data' is our network drive / folder location.
Any help greatly appreciated 😀
Hi All,
Message 9 of 35
gareth.butlerS9R7M
Apologies, the weld xml should be the one now attached.
Many thanks,
Gareth
Many thanks,
Gareth
Message 10 of 35
BDCollett
in reply to: johnsonshiue
BDCollett
Thanks for that.
The Read Only is gone but it seems to be stuck in a loop of asking to be migrated?
Apart from that it all works, no errors like Gareth is seeing. I assume that is a network drive issue.
Thanks for that.
Message 11 of 35
invtol2022desktop1wmsu
Community Visitor
Community Visitor
@gareth.butlerS9R7M
This is Rui Wang from Inventor team. With these xml files which were provided by you, the error dialog can be reproduced on my side. Could you please share the original xml files with us for more investigation as this issue should be related to migration of customize styles? Here is my email, rui.wang#autodesk.com. You can reach me via it. Thanks a lot.
-Rui
@gareth.butlerS9R7M
-Rui
Message 12 of 35
F.Steinhorst
We currently have the same problem.
The design data of the 2023 installation have not been migrated.
If we then migrate these ourselves via the manager, they are read-only!
Weld.xml is already version 4.
StudioLighting.xml checked as well (version 2016 problem)
Since there is no original, working and migrated 2023 designe data, a comparison is not possible.
Please urgently provide a complete, migrated design data for 2023, which is fully functional and can be edited in the manager. Maybe as upload here?
Thanks!
Thanks!
Message 13 of 35
GunnarNilsson
Hi
See post 6, it's the weld.xml in C:\Program Files\Autodesk\Inventor 2023\Bin\_NewStylesLibrary\Weld.xml you're supposed to change, not the weld.xml in your own migrated design data.
Hi
Message 14 of 35
F.Steinhorst
Yes, but if we change it, migration is hanging in a loop.
Message 15 of 35
F.Steinhorst
in reply to: F.Steinhorst
F.Steinhorst
We now managed to get the stilebibliothekmanager to work, after we compared all versions in
with the original installed Data Standard in
C:\Users\Public\Documents\Autodesk\Inventor 2023\Design Data
In our case
Standard.xml and SurfaceTexture.xml have had a wrong version, even after migiration.
In our case
Message 16 of 35
BDCollett
BDCollett
In our case
You can ignore the migrate message loop. Once read only is removed it will work as usual and allow you to copy and remove styles.
In our case
Message 17 of 35
rui_wang
rui_wang
@F.Steinhorst
What's the version of these two files (Standard.xml and SurfaceTexture.xml)?  Could you please check the create info in the file content? If the file was created by Inventor 2023, '<!--Created by Autodesk Inventor Version 27.0 Internal-->' was in the xml file content. And do you have other Inventor version on same machine? If yes, please close it and restart Inventor 2023 version, do style migration via style library manager again. Please feel free to let me know if you have any more comments about this. Here is my email, rui.wang#autodesk.com, you can reach me via it. Thanks again.
-Rui
@F.Steinhorst
-Rui
Message 18 of 35
BDCollett
Unsure if a new patch has broken this again. I am finding that I am getting stuck with even after migrating the styles the "Needs migration" stays and I cannot do anything past that.
Message 19 of 35
rui_wang
in reply to: BDCollett
rui_wang
@BDCollett
Could you please share your design data and the Inventor version with us for more investigation? Thanks.
You can reach me via email, rui.wang@autodesk.com
-Rui
@BDCollett
-Rui
Message 20 of 35
BDCollett
in reply to: rui_wang
BDCollett
@rui_wang
No I can't sorry as it is not one set of Design Data.
This has happened on several clients PC's now so I am seeing a pattern with 2023.0.1
I also seem to need to clear the read only on the default Design Data to migrate it.
The next time I see this I will get a copy of the data.
@rui_wang
