Style and standard editor in sheet metal not save material
creocatia3d
creocatia3d
how to save a sheet style to select in any new file?
Xun.Zhang
Hello @creocatia3d,
It is strange, could you share more details since it just works fine in my end.
Thanks!
Xun
jhackney1972
What you are probably missing is that not only does your Inventor Sheet Metal template need to have the sheet metal style added, but it must be saved to your Design Data (Styles Library) also.  To do this, you need to have an Inventor project file where the Style Library is set to Read-Write.  I do not recommend you have this setting Read-Write in your production project file because you, and others, may accidentally overwrite your styles library.  I recommend a separate template work project file.  Take a look at my screencast, it will show you what I mean.  If you save your sheet metal styles in your template and in the styles library, it will be available for all future drawings created with your sheet metal template.
John Hackney, Retired
creocatia3d
Sorry, after posting I saw that the stuff is listed in the first position of the list box.
thank´s
creocatia3d
Sorry, after posting I saw that the material is listed in the first position of the list box.
and this tip of yours complemented another doubt he had. thank you
