stress analysis force question.
slphantom
slphantom
new to the Stress analysis environment and I am wondering, if you specify a force of say 1000 lbs and place the force arrows on 4 different rest surfaces, is that 4000 lbs or 1000 divided by 4?
thanks in advance
Scott
win 11 64 bit
Nvida GeForce RTX 4000
Inventor Pro 2023
Space Explorer
Binga
With 4 forces, 1000N each, included separately (select the face, then apply):
One force 1000N, in every faces.
One force, 4000N, in every face.
Although the different results, I think the forces are distributed in each face.
(I am really scared with these differences)
Gilberto Binga
Engenheiro Mecânico - Engenheiro Mecatrônico
deLearning - YouTube Channel
Facebook | LinkedIn
LOUCO POR AUTODESK
A resposta resolve seu problema? Ajude outros usuários marcando "Aceitar como Solução"
Does the answer solve your problem? Help others checking "Accept as Solution"
Curtidas são apreciadas caso tenha gostado da informação
Likes are appreciated if you liked the information.
Binga
I found out the reason for the differences:
I have designed the 4 blocks asymmetric.
The results with the 4 blocks symmetric:
1000N applied in each face separately
4000N applied to all faces at the same time:
So, watch out with the asymmetric designs!
Gilberto Binga
Facebook | LinkedIn
LOUCO POR AUTODESK
stenhofsteenge
hello,
im trying to recreate the same but get different results. the results are minor but where is this difference coming from??
1 force 2 arrows 50000N result: 12.58
2 forces 25000N result: 12.16
Where is this difference coming from??
Kind regards,
Sten
admaiora
Can you attach the assembly?
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
stenhofsteenge
@admaiora
Please see attached.
Kind regards,
Sten
