Straight Sketch Line Not an Option with Tube & Pipe
neljoshua
Advisor Advisor
neljoshua
I am new to Tube & Pipe. Fortunately the model I am currently working on is fairly simple. I have been able to complete the routes, but something in the environment seems off; the line and spline tools are greyed out every time.
I have done some reading and have been converting all of the Autoroutes to 3D sketches. The strange thing is these sketches have straight lines in them, but I cannot add more (although I could add arcs and coils...). This has not been an issue as I have been able to use the line segments already in the sketches, but this functionality does not seem terribly helpful.
I am sure there is something that I am overlooking but I cannot figure out what it is.
Thanks for looking.
__
If this post answered your question, please select "Mark as Solution" in order to help others who may have the same (or a similar) question.
Lenovo Thinkpad P1, 2.70 GHz Intel Xeon, 32.0 GB, Windows 10 Pro
Mark.Lancaster
@neljoshua
You need to be using routing tools (route tab) and not the 3D Sketch tab.   Rigid piping is straight lines.  Do you need to work with bendable piping or flexible hosing?
Mark Lancaster
neljoshua
@Mark.Lancaster,
Thanks for the reply. I start using the Route tab, but then switch to the 3D Sketch tab after I have converted the Autoroute to a sketch. In either case, I do not see the option to add straight line segments. Is this workflow flawed or non-ideal in some way?
As I said, I could be missing something here, but I do not see how one would go about adding straight line segments to a route.
__
Mark.Lancaster
@neljoshua
If you adding onto the end of a route..   Double click on the route in your browser, starting routing again (using T&P tools) and select the end of the existing route to start.  If you want to route in between, you have to place nodes (breaking the route) on the route and delete the ones that you don't want and then re-route between the 2 broken nodes.
Mark Lancaster
neljoshua
@Mark.Lancaster,
Ah! That makes more sense.
Thanks for the clarification!
__
