.STL file lost after exporting to .STP
Daan_M
Daan_M
I'm exporting .stl file to .stp but it results in a 10kb file.
No suprise when i open/import the .stp file again, it is empty.
I'm doing the export from .stl to .stp manually by file -> Export -> Different Cad Format -> STP.
.stl and .ipt File attached for testing
EDIT:
I did some extra testing and concluded the following.
- When I create the .stl file with adjusted options, set to ASCII insteaf of binary, and then export as .stp the file is still there. The only problem is that filesize is enourmous.
- Adjusting the resultion quality has no effect
Any ideas what i'm doing wrong? Or maybe this is not possible at all?
JDMather
@Daan_M
Why are you attempting to save stl mesh to STEP rather than simply save the *.ipt solid geometry to STEP?
Daan_M
The reason for this is that the .stl files are smaller in size and get loaded/exported in faster compared to the .ipt files.
i have about 1000 files, the detail isn't very important so a smaller filesize with less detail is fine.
The .ipt size is usually about 50Mb
When using simplify i can get it down to about 25Mb it still takes too long to export to .stp (-+15 seconds)
the .stl size is about 10Mb
if this is not possible at all thats fine, then i will look for another way
TheCADWhisperer
Why do you need stp rather than simply use the stl?
And in the file that you Attached - there is a lot of internal detail that can be removed to reduce file size...
johnsonshiue
Hi! Depending on the geometry, you may be able to downsize the STEP file by changing the export spline tolerance. When exporting to STEP, click on Options button -> set "Spline fit tolerance" to 0.01mm. Is the STEP file smaller now?
Another option is to use JT. It is also a very compact format, which is usually much smaller than STEP.
Many thanks!
Software Test Engineer
