STL - Convert to Base Feature failed
WHolzwarth
Mentor Mentor
WHolzwarth
I've tried it in Inventor 2016, with no luck.
Looking for the cause, I opened the STL in Rhino5, and saved it again as STL from there. This file loaded back to 2016 could be converted to base feature.
Smiley Wink Only a hint for development. Initial STL file is attached in Zip.
Walter
Walter Holzwarth
JDMather
WHolzwarth
Here's the STL output from Rhino5, in Zip.
Thanks, Jeffrey, for testing in SWX.
Walter Holzwarth
